configure cfm domain association end-point add group
configure cfm domain domain-name association association-name ports port-list end-point [up | down] add group group_name
Description
This command allows you to create a group for an existing local end-point.
Syntax Description
domain_name
Enter the domain associated with the MA you are configuring.
association_name
IEEE 802.1ag or ITU-T Y.1731 association name.
port_list
Enter the port number you want to configure as either an UP or DOWN MEP.
Default
N/A.
Usage Guidelines
Use this command to add a group to the association.
configure cfm domain "MD1" association "MD1v1" ports 17 end-point down add group "eapsCfmGrp"
This command was first available in ExtremeXOS 15.2.
Platform Availability
